PRV Audio D290Py-S 1" Polyimide Horn Compression Driver 8 Ohm 1-3/8"-18 TPIPRV Audio's top-of-the-line D290Py-S polyimide 1" screw-on compression horn driver is designed to offer unsurpassed natural upper midrange and high frequency response, with accuracy not found in most manufacturer's stock PA speaker cabinets.
The specially designed polyimide diaphragm sounds very similar to the silk and textile dome tweeters used in high-end home audio speakers and studio monitors. PRV Audio combines this diaphragm with a high-energy motor for high output over the usable driver bandwidth for effortless, dynamic output.
High power handling is accomplished through the use of a Kapton® former and a 1-3/4" diameter voice coil, for a 90 watt RMS power rating when used with a 1,500 Hz 12 dB/octave high pass crossover, making the D290Py-S a drop-in upgrade replacement horn driver for nearly any speaker cabinet with an industry standard 1-3/8"-18 TPI horn. Spring-loaded wire terminals facilitate quick connection.
Also available in a 2/3-bolt model.
Specifications: • Power handling: 90 watts RMS with recommended crossover of 1,000 Hz, 12 dB/octave slope • VCdia: 1.75" • Impedance: 8 ohms • Frequency response: 650-19,000 Hz • SPL: 109 dB 2.83V/1m • Dimensions: 4.72" diameter x 3.07" depth (including threads) • Net weight: 4.96 lbs. See the Related Items section for the replacement diaphragm.
