  • PRV Audio ADM25-25 2/3-Bolt Driver to 1-3/8" 18 TPI Horn Adapter
PRV Audio
Part #294-2940
PRV Audio
Part #294-2940
Model: ADM25-25
The ADM25-25 adaptor allows most 2 or 3-bolt 1" compression drivers to fit on any 1-3/8" 18 TPI horn.
  • Rugged ABS plastic construction with 1/4" thick mounting plate
  • Converts most 2/3-bolt 1" compression drivers to fit 1-3/8" 18 TPI horns
  • Standard bolt spacing of 3" for 2-bolt and 2-1/4" for 3-bolt drivers
Your Price: $8.31
MSRP: $10.39
Save $2.08 (20%)
PRV Audio's ADM25-25 adaptor allows most 2 or 3-bolt 1" compression drivers to fit on any 1-3/8" 18 TPI horn. This adaptor has a gradual taper from the compression driver to horn to minimize any possible issues caused by sharp edges.
Dimensions: • Diameter: 3.5" • Depth: 0.9375" • Mounting Plate Thickness: 0.25"
BrandPRV Audio
ModelADM25-25
Part Number294-2940
UPC799928734417
Weight0.1
ConstructionABS
Entry / Throat Diameter1"
Mounting TypeHorn Adapter
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
