  • PRV Audio 8MR500-4 BULLET 8" Midrange Speaker 4 Ohm
PRV Audio
Part #294-3143
PRV Audio
Part #294-3143
Model: 8MR500-4 BULLET
Continuing PRV Audio's "pro audio on wheels" concept, the 8MR500-4 BULLET 8" midrange is built to deliver the same performance as a professional loudspeaker. Featuring an aluminum phase plug for improved high frequency response, this driver is able to give high levels of output from your custom door or rear deck.
  • Extremely wide frequency response from 95 to 20,000 Hz for smooth midrange output
  • 95 dB efficient and 250 watt RMS power handling for incredible output capability
  • Aluminum phase plug improved high frequency response on and off-axis
  • Powerful motor and low moving mass to provide incredible dynamics and detail
Your Price: $54.91
MSRP: $68.64
Save $13.73 (20%)
16In Stock
The 8MR400-4 BULLET 8" midrange speaker uses a "bullet" phase plug made from pure aluminum to lower inductance and act as a heat sink cooling system for the voice coil. Machined to perfection for even sound dissipation the phase plug also improves off-axis frequency response. Beyond good looks, this cone is extremely light, providing excellent damping to keep an incredibly natural yet accurate sound with incredible efficiency.
A triple roll cloth surround, combined with an optimized fiber pressed paper cone, ensure the speaker’s frequency response is smooth and extends to high range making an easy transition to a super tweeter. The suspension design of the 8MR500-4 BULLET features a single layer spider – which connects to the coil former with premium stitched lead wires. The cone is driven by a copper-clad aluminum wire voice coil providing high efficiency and excellent power handling.
This driver is constructed of high-performance characteristics and high-quality components to provide exceptional clarity, detail, and dynamic sound. You can expect outstanding sound stage quality and realistic sound reproduction for a great value. This is the new standard of value in high-performance bullet speakers.
Built to perform and able to handle 500 watts of continuous power, this midrange is the perfect option to replace those old 2-way or 3-way coaxial speakers. Engineered and designed to easily transform a stock system into one that can deliver concert levels. The 8MR500-4 BULLET is ideal for audiophiles seeking tremendous output without radical modifications.
BrandPRV Audio
Model8MR500-4 BULLET
Part Number294-3143
UPC619620087638
Weight5.55
Nominal Diameter8"
Bolt Circle Diameter8
Power Handling (RMS)250 Watts
Power Handling (MAX)500 Watts
Frequency Response95 to 20,000Hz
Sensitivity95dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)78.2Hz
DC Resistance (Re)3.5Ω
Voice Coil Inductance (Le)0.132mH
Mechanical Q (Qms)20.8
Electromagnetic Q (Qes)0.48
Total Q (Qts)0.46
Compliance Equivalent Volume (Vas)0.73ft³
Mechanical Compliance of Suspension (Cms)0.36mm/N
BL Product (BL)6.45T·m
Diaphragm Mass Inc. Airload (Mms)11.5g
Maximum Linear Excursion (Xmax)3.25mm
Surface Area of Cone (Sd)241cm²
Cone MaterialTreated Paper
Voice Coil Wire MaterialCCA
Overall Outside Diameter8.27"
Baffle Cutout Diameter7.32"
Depth3.46"
Sealed Volume0.4ft³
Sealed F3134.7Hz
Vented Volume0.88ft³
Vented F370.4Hz
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE 20%
Shadow Mounts DTS65 Universal Sturdy Desktop Tabletop Entertainment Center TV Monitor Stand Up to 65"
