  • PRV Audio 3DF500/3500 3-Way Crossover Terminal 500/3,500 Hz 12 dB/Octave Selectable 4-8 Ohm
PRV Audio
Part #294-3046
PRV Audio
Part #294-3046
Model: 3DF500/3500
Get your professional audio speaker cabinet up and running like new, or build your own custom speaker, with the PRV Audio 3DF500/3500 500 Hz and 3,500 Hz three-way passive crossover. Suitable for 4 or 8 ohm woofers and with adjustable attenuation on the midrange and tweeter output, this crossovers is suitable for a variety of designs.
  • 4 or 8 ohm woofer impedance for use with single or dual woofer cabinets
  • Selectable 0, 3, or 6 dB attenuation for midrange and high frequency output
  • 12 dB/octave rolloff for woofer, midrange, and tweeter
  • Made in Brazil
Your Price: $97.41
MSRP: $121.76
Save $24.35 (20%)
Estimated back in stock 5/1/2025
Alert Me When Available
PRV Audio's 3-way 3DF500/3500 crossover (with crossover points at 500 and 3,500 Hz) is designed to be used with passive (unpowered) speakers. Selectable 4 or 8-ohm woofer impedance and 12 dB/octave woofer low pass slops allow you to use this crossover with single and double woofer 3-way cabinets. Level adjustments of 0, 3, or 6 dB on the midrange and tweeter output makes it easy to attenuate high efficiency drivers to match your woofer output.
High quality components are used throughout for longevity and great sound, and the impedance, as well as high frequency attenuation, is selected by convenient on-board jumpers. Made in Brazil.
Specifications: • Power handling: 450 watts RMS, 900 watts program power • Crossover points: 500 Hz low-pass 12 dB/octave slope for woofers/ 500 to 3,500 Hz, 12 dB/octave band-pass for midrange/ 3,500 Hz, 12 dB/octave high-pass for tweeter • Driver impedance: 4 or 8 ohm woofer / 8 ohm midrange/ 8 ohm tweeter • Attenuation: 0, 3, or 6 dB for tweeter and midrange.
BrandPRV Audio
Model3DF500/3500
Part Number294-3046
UPC602938022958
Weight2.65
Crossover Type3-Way
