PRV Audio 2DF2K Two-Way Crossover Terminal 2,000 Hz 12 dB/Octave 8 Ohm
- High quality components can handle up to 450 watts RMS
- Common 2,000 Hz crossover point is compatible with many popular horn drivers
- Perfect replacement or upgrade crossover for two-way speaker cabinets
- Parallel wired speakON-compatible input/output connectors
We'll send you an email when PRV Audio 2DF2K Two-Way Crossover Terminal 2,000 Hz 12 dB/Octave 8 Ohm is back in stock or available for preorder.
