  • PRV Audio 15SW2000 15" Pro Audio Subwoofer 8 Ohm
PRV Audio
Part #294-3007
PRV Audio
Part #294-3007
Model: 15SW2000
The 15SW2000 is the first 15" pro audio subwoofer from PRV Audio. It offers the user an incredible punch to high power pro audio systems. The 15SW2000 loudspeaker has a very well-designed forced cooling system to ensure proper air ventilation for extended play.
  • Impressive 96 dB sensitivity
  • Large 4" voice coil for high power handling
  • Forced air cooling system
  • Extremely linear 12.5 mm Xmax
Your Price: $189.91
MSRP: $237.39
Save $47.48 (20%)
Order in the next 1 hr 28 min to ship today. Details
18In Stock
The 15SW2000 is the first 15" pro audio subwoofer from PRV Audio, It offers the user an incredible punch to high power pro audio systems. The 15SW2000 loudspeaker has a very well-designed forced cooling system to ensure proper air ventilation for extended play. The woven surround offers linear excursion along its impressive 12.5 mm XMAX.
The enhanced voice coil and cone material along with its ability to reproduce extremely low frequencies will ensure this is your subwoofer of choice from now on. The large 4" voice coil accepts the abuse of higher power systems while staying cool with the side forced air cooling system.
BrandPRV Audio
Model15SW2000
Part Number294-3007
UPC602938022347
Weight28.8
Nominal Diameter15"
Frequency Response45 to 2,300Hz
Sensitivity96dB 2.83V/1m
Voice Coil Diameter4"
Resonant Frequency (Fs)52.9Hz
DC Resistance (Re)5.5Ω
Voice Coil Inductance (Le)1.51mH
Mechanical Q (Qms)16.54
Electromagnetic Q (Qes)0.57
Total Q (Qts)0.55
Compliance Equivalent Volume (Vas)2.17ft³
Mechanical Compliance of Suspension (Cms)0.05mm/N
BL Product (BL)23.19T·m
Diaphragm Mass Inc. Airload (Mms)169.1g
Maximum Linear Excursion (Xmax)12.5mm
Surface Area of Cone (Sd)908cm²
Voice Coil FormerFiberglass
Overall Outside Diameter15.47"
Baffle Cutout Diameter13.98"
Depth7.11"
Sealed Volume2ft³
Sealed F376.6Hz
Vented Volume3.75ft³
Vented F344.1Hz
