  • PRV Audio 10W650A Alto Series 10" Woofer 8 Ohm
PRV Audio
Part #294-2725
PRV Audio
Part #294-2725
Model: 10W650A
PRV Audio's Alto Series 10W650A is an impressive driver, without a high-end price. This 8 ohm 10" is a great woofer for any high output system such as pro audio or even high SPL automotive systems. With 97 dB efficiency and 325 watt of continuous power handling, this driver is capable of extremely high output. In addition, the 10W650A has a wide frequency response of 65 to 5,000 Hz, making it suitable for use in high-end guitar and bass amps.
  • Vented pole piece keeps the 2.5" VC cool for continuous high power handling
  • Cloth double roll surround and large raised spider can take the high demands of pro sound
  • 65 to 5,000 Hz frequency response makes this mid/woofer suitable for two or three-way designs
  • Capable of extreme output levels with 97 dB sensitivity and 325 watt power handling
Your Price: $77.91
MSRP: $97.39
Save $19.48 (20%)
Order in the next 0 hr 11 min to ship today. Details
23In Stock
BrandPRV Audio
Model10W650A
Part Number294-2725
UPC799928734820
Weight11.3
Nominal Diameter10"
Power Handling (RMS)325 Watts
Power Handling (MAX)650 Watts
Frequency Response75 to 5,500Hz
Sensitivity97dB 2.83V/1m
Voice Coil Diameter2.5"
Resonant Frequency (Fs)72.31Hz
DC Resistance (Re)6.1Ω
Voice Coil Inductance (Le)0.79mH
Mechanical Q (Qms)16.34
Electromagnetic Q (Qes)0.47
Total Q (Qts)0.46
Compliance Equivalent Volume (Vas)1.2ft³
Mechanical Compliance of Suspension (Cms)0.142mm/N
BL Product (BL)14.09T·m
Diaphragm Mass Inc. Airload (Mms)34.04g
Maximum Linear Excursion (Xmax)4.5mm
Surface Area of Cone (Sd)415cm²
Cone MaterialPaper
Surround MaterialCloth
Voice Coil Wire MaterialCCA
Overall Outside Diameter10.1"
Baffle Cutout Diameter9.25"
Depth4.72"
Sealed Volume0.63ft³
Sealed F3124.6Hz
Vented Volume1.25ft³
Vented F368.5Hz
