  • PKCELL Flat Top 14500 Li-Ion 3.7V 800mAh Rechargeable Battery
PKCELL
Part #142-200
PKCELL
Part #142-200
Always have an extra charged backup battery waiting, or start a new project with this 3.7 VDC 14500 Li-Ion battery for your flashlight or other electronic devices.
  • Long lasting standby charge
  • Standard size 14500 Li-Ion battery
  • 3.7 VDC for high voltage projects
  • CE certified
Your Price: $4.29
MSRP: $4.99
Save $0.70 (14%)
Quantity:Qty: 1-3 $4.29/ea
Quantity:Qty: 4+$3.84/ea
Estimated back in stock 5/30/2025
Alert Me When Available
A growing number of electronic devices use 14500 Li-Ion batteries. Flashlights are using the 14500 battery to power high brightness LED bulbs, and to provide longer standby time when not in use. Previous rechargeable battery flashlights had to be left on the charger almost all the time so that it would be ready to use in a moment's notice. This 14500 Li-Ion battery can be left off the charger for months and still have over 90% of its charge. This enables you to charge an extra battery and have it ready to use in your flashlight in case you are going to be away from electricity for a long period of time or you forget to charge your original battery.
This battery is the same size as a AA battery, but do not use it in place of a AA. Since the 14500 fits into AA holders, many new projects requiring higher voltage are using this Li-Ion battery. It's more than double the voltage of a AA battery, and the standby charge versus other rechargeable batteries is up to three times longer. Save space by using three 14500 batteries instead of eight rechargeable AA batteries in a 12 VDC project.
Note: Do not throw the battery into the fire. Do not solder directly to the battery. Do not store the battery in heavy static electricity areas. Do not mix the battery with different brands, chemicals, or amperage ratings. Wash your skin or clothing immediately if the battery leaks onto them. If any chemicals get into your eyes do not rub them, but wash your eyes with clean water and call a doctor. Keep out of reach of young children to avoid swallowing.
Specifications: • Voltage: 3.7 DC • Current rating: 800mAh • Charging environment temperature range: 32° to 113° F • In use temperature range: -4° to 140° F • Size: 0.56" Dia. x 1.95" H.
BrandPKCELL
Part Number142-200
UPC848864044750
Weight0.049
Size14500
TechnologyLi-Ion
Voltage3.7V
