  • PKCELL Flat 3.7V 500mAh Rechargeable Lithium Polymer 503035 Battery with Plug
PKCELL
Part #142-213
PKCELL
Part #142-213
Replace or add a Lithium Polymer battery to your next 4-5 VDC project. The slim size and 500mAh rating enables it to fit into small projects and power small amplifiers.
  • PCM over/under charge protection built-in for safety
  • Only 0.2" thick enables it to fit into smaller projects where space is limited
  • 500mAh rating powers most 4-5 VDC projects
Your Price: $7.98
MSRP: $12.99
Save $5.01 (39%)
Quantity:Qty: 1-3 $7.98/ea
Quantity:Qty: 4-11 $7.42/ea
Quantity:Qty: 12-79 $6.78/ea
Quantity:Qty: 80+$6.38/ea
Estimated back in stock 5/2/2025
Alert Me When Available
Why through away expensive electronics when the battery won't recharge anymore? This Lithium Polymer battery replaces batteries in various types of electronic products. You will find it in many portable Bluetooth speakers, media players and other rechargeable devices.
Use this battery in your next 5 VDC portable project. Its size enables it to fit into small portable Bluetooth speaker projects that have up to 5W of power output or build a small portable 5W amplifier to hook to small bookshelf speakers. This battery also powers many Raspberry Pi and Arduino projects. Recharge the battery with a 5 VDC power adapter. Its over/under charge circuit protects the battery from being over charged.
Note: If using the included plug make sure the polarity matches the socket on the board. If not, you can switch the wires by lifting up the plastic tap above of each terminal and pulling out the wire with the terminal. Use a non-metal tool to lift the tab to avoid shock.
Specifications: • Dimensions without leads: 1.2" H x 1.43" W x 0.2" D •Leads: 2" with JST type PH 2.0 plug • Maximum voltage output: 4.2 VDC • Current rating: 500mAh • Battery type: Lithium Polymer (LiPo).
BrandPKCELL
Part Number142-213
UPC848864065090
Voltage3.7V
