  • PA Knock-Down Trapezoid Plywood Speaker Cabinet for 12" Driver
CLEARANCE PA Knock-Down Trapezoid Plywood Speaker Cabinet for 12" Driver
Part #245-324
Part #245-324
This American-cut knock-down trapezoid cabinet is perfect for your next PA speaker system project.
  • Easily assembled plywood panels with CNC-dadoed joints
  • Trapezoid shape facilitates arraying multiple speakers
  • 11" cut-out fits most 12" drivers
  • Wood screws included
  • Easy-to-follow instruction manual
  • You provide the labor, wood glue, and components!
This American-cut knock-down trapezoid cabinet is perfect for your next PA speaker system project. Pre-cut hole accommodates most 12" drivers. Includes CNC-cut plywood knock-down panels, optional front protection grill supports, wood screws, and assembly instructions. Popular trapezoid shape can be used horizontally as a floor/stage monitor, or stood upright for traditional vertical applications. The 3/4" plywood used in this cabinet is exceptionally smooth, dense, strong, and virtually non-resonant. The high quality low-loss wood means more of the power that drives the speaker will turn into sound and less will be used to shake, rattle, or resonate the cabinet.
Specifications:• Internal volume: 1.6 cu. ft. • Dimensions: 24-1/2" H x 17" W (front), 10-1/4" (rear) x 13-1/8" D.
Part Number245-324
UPC844632090486
Weight25.7
