  • Outdoor HDTV Digital Bow Tie TV Antenna
Part #210-542
Part #210-542
This antenna provides HD and digital local programming on your television for free. It's perfect for picking up distant channels in one direction.
  • 10 dBi gain for picking up distant stations
  • Compact size mounts in the attic or on a small outside pole
  • Includes mounting hardware for up to 1-3/4" diameter pole (pole sold separately)
  • 470-860 MHz frequency range for digital TV
Your Price: $14.98
MSRP: $26.99
Save $12.01 (44%)
Order in the next 19 hr 14 min to ship today. Details
112In Stock
Use this antenna for picking up extra digital channels over indoor antennas. This antenna's design works great for picking up distant channels in one general direction. If you're too far away from a major city to pick up channels from an indoor antenna, try this antenna first. It easily mounts in the attic or on a small pole (sold separately), and it uses standard CATV coax cable for quick installation. Point the antenna towards the biggest city located closest to you and scan for channels in antenna or air mode from your TV's menu options. Enjoy the extra channels you'll pickup over an inside antenna.
Don't let the low cost and small size fool you. This antenna picks up stations up to 50 miles away. The small 16" x 22" x 7" size enables you to mount this light 2 lb. antenna high without using a large antenna tower for support. Terrain is always a factor when trying to pick up TV stations, so for the best reception mount the antenna on a pole that extends higher than the peak of your house. The antenna accepts poles up to 1-3/4" in diameter.
Part Number210-542
UPC848864059181
Weight2.75
