NEW Waterproof Outdoor Utility Box 8.7"x6.7"x4.3" (170x220x110mm) with Mounting Plate and Wall Brackets
- Crafted from high-quality ABS material to provide exceptional resistance against impact and ensure excellent electrical insulation.
- IP67 waterproof and weatherproof design, offering superior protection against water, rain, dust, snow, oil, UV rays, and other environmental elements
- Two durable premium ABS plastic latches provide quick and easy access whenever required
- Lock hole is available to offer added security and deter tampering
- Convenient removable plastic internal grid enables you to mount electrical components to it outside the box
- Four wall mounting brackets are included, enabling you to securely attach the junction box to brick, wood, or any other type of construction material
- Drillable plastic makes it easy to add waterproof connectors/inserts
We'll send you an email when Waterproof Outdoor Utility Box 8.7"x6.7"x4.3" (170x220x110mm) with Mounting Plate and Wall Brackets is back in stock or available for preorder.
