  • Neutrik NL4FC speakON Connector 4 Pole Cable Mount
CLEARANCE Neutrik NL4FC speakON Connector 4 Pole Cable Mount
Neutrik
Part #092-050
Neutrik
Part #092-050
Model: NL4FC
The Neutrik NL4FC speakON connector is patent protected, reliable, cost effective, and extremely durable. The Neutrik NL4FC speakON connector is part of a series of professional speaker and amplifier connectors offering the "quick lock" locking system.
  • Solderless 4-conductor terminations with quick and easy assembly
  • Field serviceable, robust, and unbreakable
  • Fail-safe, long life audio/electrical termination integrity
  • Developed for frequently connected/disconnected systems with operator and equipment safety in mind
Neutrik's NL4FC 4-pole connector is part of the speakON series of professional speaker and amplifier connectors recognized as the industry standard. The speakON system now offers the "quick lock" locking system and recently redesigned inserts for the cable ends. The NL4FC's inserts feature solderless connections using the new pozidrive and slot combination screw terminals with a captive pressure plate. No special tools are required, making the Neutrik NL4FC connectors 100% field repairable.
The contacts in the NL4FC are touch proof and designed to prevent damage from arcing if disconnected under load, ensuring fail-safe conditions for both the equipment and the operator. The Neutrik NL4FC meets the prevailing safety standards of IEC65, IEC348, CE, and CSA, and are UL rated (file #E135070).
Specifications: • Connector type: Cable end connector, 4-pole • Accepts 5-15 mm OD cable • Neutrik model NL4FC.
BrandNeutrik
ModelNL4FC
Part Number092-050
Weight0.1122
Circuit4-Pole
GenderFemale
Mounting TypeCable Mount
