  • Neutrik NE8FDP Ethercon RJ45 Feed Through Connector
Neutrik
Part #092-188
Neutrik
Part #092-188
Model: NE8FDP
EtherCon® ruggedized RJ45 connectors provide solutions for data transfer in harsh demanding environments by offering a cable carrier and receptacle that helps to protect the contacts of the RJ45 connections.
  • Protects contacts and connections
  • Compatible with NE8Mx cable housings
  • Rugged locking construction
  • Nickel "D" Series frame
Your Price: $11.23
MSRP: $14.99
Save $3.76 (25%)
Quantity:Qty: 1-99 $11.23/ea
Quantity:Qty: 100-249 $10.48/ea
Quantity:Qty: 250+$10.08/ea
Estimated back in stock 12/26/2024
Alert Me When Available
EtherCon® ruggedized RJ45 connectors provide solutions for data transfer in harsh demanding environments by offering a cable carrier and receptacle that helps to protect the contacts of the RJ45 connections. Designed to protect the fragile latch and cover of standard RJ45 connectors from breakage, you will find uses for this connector system in Ethernet networking of audio, commercial, entertainment, stage production, DMX lighting, industrial and outdoor Internet access applications.
The Ethercon series offers both male cable carriers and assembled female receptacles. The cable end offers a robust diecast shell as a carrier for pre-assembled RJ45 plugs. Female chassis connectors are based on the current Neutrik "A" series as well the "D" series of XLR receptacles with secure latching system - a feature not found on other RJ45 receptacles. Termination is offered in both IDC Krone and IDC 110 punch down terminals. Neutrik Ethercon products comply with Category 5 shielded or unshielded and are compatible for use with 10 Base-T and 100 Base-TX systems.
Specifications: • Connector type: RJ45 feedthrough, "D" style, nickel • Mfg. #NE8FDP.
BrandNeutrik
ModelNE8FDP
Part Number092-188
Weight0.1
MONSTER DEAL
OF THE WEEK
$129.49 EACH
SAVE $14
Dayton Audio HTA20 20 Watt Integrated Stereo Hybrid Tube Amplifier With USB-DAC and Bluetooth 5.0
