  • Neutrik NC3FRX XLR Connector 90 Degree Right Angle Female Nickel
Neutrik
Part #092-026
Neutrik
Part #092-026
Model: NC3FRX
The RX Series is the right angle version of the XX cable connector series. 3 pole right angle female cable connector, nickel housing, and silver contacts.
  • Extra slim right-angle connector
  • 5 selectable cable outlet positions
  • Unique cage design of female contact for low contact resistance and high integrity
  • Female contact incorporates a solder barrier to prevent solder running into the contact mating area
  • Female connector with improved solid metal latch which is larger and easier to handle
  • Additional ground spring contacts for better shell ground continuity
  • Improved chuck type strain relief provides higher pull-out force and makes assembly easy and fast
Your Price: $9.48
MSRP: $12.99
Save $3.51 (27%)
Quantity:Qty: 1-99 $9.48/ea
Quantity:Qty: 100-249 $8.97/ea
Quantity:Qty: 250+$8.63/ea
70In Stock
The RX Series is the right angle version of the XX cable connector series. The successor of the RC series offers several new features which make it more reliable, easier to assemble and improves contact integrity as well cable strain relief. 3 pole right angle female cable connector, nickel housing, and silver contacts.
BrandNeutrik
ModelNC3FRX
Part Number092-026
Weight0.12
Conductors3-Pin
GenderFemale
Mounting TypeCable Mount
