Neutrik NBB75DFIB BNC "D" Feed-Through Isolated Black
- BNC female to female coupler
- Familiar "D" Series frame
- Durable construction
- Black finish
BNC Bulkhead Chassis Connectors. Based on a new production technology, the machined brass connector body provides and extremely rugged and non-abrasive connection over long term use. They are an ideal combination when used in conjunction with Neutrik 75 ohm BNC Rear Twist or Push-Pull cable connectors. Available in isolated or grounded versions, in "D" shaped housing or single feed through chassis mountings. Isolated versions solve potential grounding problems and prevent common-mode influence with other connections conducted over the same panel ground potential. Gold plated center contact. Excellent return loss / VSWR rating.
• Connector Type: BNC Isolated Feed Through • Housing: "D" Series • Shell Color: Black • Mfg. #NBB75DFIB
Product Details | |
Brand | Neutrik |
Model | NBB75DFIB |
Part Number | 092-256 |
UPC | 844632005039 |
Unit of Measure | Each |
Weight | 0.1 |
Product Specifications | |
Gender | Feedthrough |
Mounting Type | Chassis / Panel Mount |
