  • Neutrik NBB75DFI BNC "D" Feed-Through Isolated Nickel
1 Question, 2 Answers or
Neutrik
Part #092-254
Neutrik
Part #092-254
Model: NBB75DFI
Neutrik connectors are the choice of professionals everywhere. This BNC feed-through is an ideal choice when used in conjunction with Neutrik 75 ohm BNC Rear Twist or Push-Pull cable connectors.
  • BNC female to female coupler
  • Familiar "D" Series frame
  • Durable construction
  • Nickel finish
Your Price: $10.46
MSRP: $13.99
Save $3.53 (25%)
Quantity:Qty: 1-99 $10.46/ea
Quantity:Qty: 100-249 $9.91/ea
Quantity:Qty: 250+$9.53/ea
Order in the next 9 hr 34 min to ship today. Details
111In Stock
BNC Bulkhead Chassis Connectors. Based on a new production technology, the machined brass connector body provides and extremely rugged and non-abrasive connection over long term use. They are an ideal combination when used in conjunction with Neutrik 75 ohm BNC Rear Twist or Push-Pull cable connectors. Available in isolated or grounded versions, in "D" shaped housing or single feed through chassis mountings. Isolated versions solve potential grounding problems and prevent common-mode influence with other connections conducted over the same panel ground potential. Gold plated center contact. Excellent return loss / VSWR rating.
• Connector Type: BNC Isolated Feed Through • Housing: "D" Series • Shell Color: Nickel • Mfg. #NBB75DFI
BrandNeutrik
ModelNBB75DFI
Part Number092-254
UPC703272072354
Weight0.1
GenderFeedthrough
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
