  • Morel TiCW 638Nd Titanium Series Hybrid Cu 6" Woofer 8 Ohm
Morel
Part #297-105
Morel
Part #297-105
Model: TiCW 638Nd
For serious speaker builders that demand the world's best drivers, look no further than Morel's Titanium Advanced woofer series. The 6" TiCW 638Nd features a Coppersleeve Neolin motor and a titanium bobbin for ultra-quick transient response and a Uniflow chassis for reduced power compression.
  • Open Uniflow aluminum diecast chassis for reduced reflections
  • Hybrid neodymium/ferrite magnet ferrite system
  • Titanium coil bobbin for low energy storage
  • 3" Hexatech aluminum voice coil
  • High 1,000W instantaneous power handling
  • Coppersleeve Neolin motor
Your Price: $344.00
MSRP: $451.99
Save $107.99 (24%)
Since 1975, Morel has been on an ever-evolving quest to create the perfect, ultimate loudspeaker. This dedication is apparent in every product they produce: tweeters, midranges, woofers, and finished systems that serve the Hi-Fi, home theater, and car audio markets. Morel systems are today sold in more than 55 countries around the globe. Their products are made with exceptional care; each is assembled by hand and extensively tested, undergoing seven different quality assurance steps, to ensure only the highest standards are met.
Morel Titanium Advanced Series
The Titanium Advanced woofer series from Morel is the latest leap forward in woofer design. Huge 3" Hexatech™ aluminum voice coils (that use hexagonal shaped wire for high sensitivity and power handling) are wound onto titanium bobbins for amazingly low energy storage, resulting in lightning quick transients for superior attack and decay transients. Qms is also raised, and allows for a wider range of enclosure options. Three magnetic systems are available: dual ferrite, Hybrid™ neodymium/ferrite, and Hybrid™ neodymium/ferrite with a Coppersleeve Neolin™ motor. Each is available in 4 and 8 ohm impedance.
Uniflow­™ Aluminum Diecast Chassis
All of this wouldn't mean anything if the air swept by the driver got trapped in the motor or frame. Morel designed the Uniflow chassis to be as open and sonically transparent as possible. An over-sized vent on the pole piece, a frame-suspended spider, and exposed voice coil combine to virtually eliminate reflections and output-robbing power compression. The Uniflow chassis also allows for the use of an over-sized spider for complete control of the over-sized voice coil.
The 6" TiCW 638Nd woofer features a Hybrid neodymium/ferrite magnet system, Coppersleeve Neolin motor (for the best possible transient response), 4-ohm impedance, and a unique, one-piece DPC (Damped Polymer Composite) cone that offers flat frequency response from 40 Hz to 4,500 Hz on-axis, and from 40 Hz to 4,000 Hz off-axis. Its large voice coil allows it to handle 10 ms peak power transients of up to 1,000 watts when used correctly.
Specifications analyzed at 1V for more accurate cabinet design.
BrandMorel
ModelTiCW 638Nd
Part Number297-105
UPC848864001999
Weight2.6
Nominal Diameter6"
Power Handling (RMS)150 Watts
Frequency Response40 to 4,500Hz
Sensitivity87dB 2.83V/1m
Voice Coil Diameter3"
Resonant Frequency (Fs)33Hz
DC Resistance (Re)5.4Ω
Voice Coil Inductance (Le)0.32mH
Mechanical Q (Qms)2.47
Electromagnetic Q (Qes)0.32
Total Q (Qts)0.29
Compliance Equivalent Volume (Vas)1.02ft³
Diaphragm Mass Inc. Airload (Mms)16.8g
Maximum Linear Excursion (Xmax)5.25mm
Cone MaterialPoly Composite
Voice Coil FormerTitanium
Magnet MaterialNeodymium
Overall Outside Diameter6.3"
Baffle Cutout Diameter5.51"
Depth2.72"
Sealed Volume0.3ft³
Sealed F362.7Hz
Vented Volume0.6ft³
Vented F334.7Hz
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
