  • Mogami W2534 Neglex Quad High Definition Microphone Signal Cable 164 ft. (50m)
Mogami
Part #103-1009
Mogami
Part #103-1009
Model: 2534
W2534 Neglex Quad cable by Mogami is designed to preserve your signal perfectly, while rejecting interference and noise. Four 24 AWG conductors plus a served (spiral) copper shield are covered by a 0.236" PVC jacket which is rugged enough for the road, but very easy to work with.
  • Transparent sound, excellent noise rejection
  • PVC jacket is easy to handle & extremely durable
  • 4 x 24 AWG conductors
  • Easy to work with 0.236" O.D.
  • Made in Japan
Your Price: $219.98
MSRP: $298.99
Save $79.01 (26%)
2In Stock
Mogami's W2534 has become the de facto standard for high quality mic cable due to its superior RF/EM rejection and transparency. W2534 Neglex Quad cable by Mogami is designed to preserve your signal perfectly, while offering 10 - 20 dB better signal to noise than competing twisted pair cables. Four 24 AWG conductors are insulated with XLPE (cross-linked polyethylene) for excellent electrical characteristics and reduced shrink-back when soldering. A served (spiral) bare copper shield provides superior sound quality compared to foil or braided shields, and makes for easy termination.
Every time you perform or record, your reputation is on the line. Why take the risk of using substandard cables? Since 1957, Mogami has staked their reputation on every cable they've produced. More and more musicians, recording and broadcast studios, and professional production companies not only use Mogami, they demand it. From Fleetwood Mac to Foo Fighters, from Prince to Pearl Jam, just about any modern recorded music you've ever heard has passed through Mogami cable at some point in its production. Thus, Mogami has positioned themselves as the world's leader in audio cable manufacturing, and earned the right to be called "The Cable of the Pros." Made in Japan.
Specifications: • Conductor size: 24 AWG (0.226 mm²) • Conductor insulation: 0.063" (1.6mm) polyethylene • Sub-shield diameter: 0.12" (3.04 mm) carbon PVC • Outer jacket size: 0.189" (4.8 mm) • Outer jacket material: PVC.
BrandMogami
Model2534
Part Number103-1009
UPC801813010190
Weight5.65
Jacket ColorBlack
Wire Gauge24
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
