Mogami W2319 High Impedance 23 AWG Guitar Instrument Signal Cable 656 ft. (200m)W2319 guitar & instrument cable by Mogami is designed to preserve your tone, while rejecting interference and microphonics. A 23 AWG center conductor is sheathed in polyethylene insulation, then a conductive PVC sub-insulation, and finally covered in spiral shield and 0.197" PVC jacket for maximum clarity, flexibility, and durability.
Every time you perform or record, your reputation is on the line. Why take the risk of using substandard cables? Since 1957, Mogami has staked their reputation on every cable they've produced. More and more musicians, recording and broadcast studios, and professional production companies not only use Mogami, they demand it. From Fleetwood Mac to Foo Fighters, from Prince to Pearl Jam, just about any modern recorded music you've ever heard has passed through Mogami cable at some point in its production. Thus, Mogami has positioned themselves as the world's leader in audio cable manufacturing, and earned the right to be called "The Cable of the Pros." Made in Japan.
Specifications: • Conductor size: 23 AWG (0.305 mm²) • Conductor insulation: 0.063" (1.6 mm) polyethylene • Sub-shield diameter: 0.071" (1.8 mm) carbon PVC • Outer jacket size: 0.197" (5 mm) • Outer jacket material: PVC.
