  • Morel Ardon Premium 2-Way MT Bookshelf Speaker Kit with Knock-Down Cabinet
CLEARANCE Morel Ardon Premium 2-Way MT Bookshelf Speaker Kit with Knock-Down Cabinet
Part #300-7144
Part #300-7144
Designed by Morel engineers, the Ardon 2-way bookshelf speaker kit makes it easy to build your own premium quality, low distortion speaker that offers elite performance to audiophiles on a budget. Using drivers created exclusively for the Ardon kit, this compact design delivers surprisingly deep and articulate bass response, realistic vocal reproduction, accurate high frequencies, and pinpoint imaging.
This kit includes almost everything you need to build a single high-end bookshelf speaker, including: a knock-down cabinet, drivers, crossover components, screws, and binding posts.
  • Designed by Morel to produce premium performance, natural response, and high output capability
  • Extremely rigid 3/4" MDF enclosure uses double rabbeted joints and extensive bracing
  • Damped poly cone 6" woofer with 3" voice coil for dynamic response and low distortion
  • Compact 1-1/8" soft dome tweeter provides flat response with superb accuracy
  • Remarkably smooth response on and off-axis for room filling audio and large sweet spot
  • Customize the Ardon to your personal tastes - finishing options are limitless
  • The Ardon speaker kit includes nearly everything required to build a single speaker
Created from the ground up to provide accurate and detailed response, the Morel Ardon 2-way compact bookshelf speaker kit brings a new level of affordability to the premium audiophile speaker market. Designed by the engineers at Morel, the Ardon will encompass you with superb sound for an engaging, life-like music performance you will never forget. Capable of powerful and dynamic bass response, articulate midrange, and natural high frequencies… everything people expect from Morel's award-winning line of speakers.
Using drivers engineered explicitly for the Ardon speaker kit, this system can provide high output with low distortion. With a large voice coil and powerful motor, the woofer produces deeper bass response and better dynamics than you would expect from such a compact speaker. The high frequencies are handled by a 1-1/8" soft dome tweeter that creates Morel's iconic smooth and detailed treble. Thanks to the excellent driver and crossover integration, the Ardon delivers remarkably flat response through the critical midrange (±1.5 dB from 300 to 7,000 Hz) allowing for realistic and convincing vocal reproduction.
The compact size and surprising output capability makes the Ardon extremely flexible and suitable for a variety of situations. Enjoy premium audio fidelity in offices, bedrooms, and other smaller spaces without the need for a subwoofer. A pair can still produce convincing and powerful reproduction for a larger room, especially when matched with a subwoofer. Finally, this is an excellent kit for a truly engrossing home theater experience when used as the left, center, right, and surround channels.
About the Drivers
Designed and built specifically for the Ardon speaker kit, the KW-1 6" damped polymer composite cone woofer from Morel combines an exceptionally smooth response with low distortion. Featuring Morel's lightweight 3" diameter Hexatech aluminum voice coil, the KW-1 can handle up to 150 watts RMS while keeping excursion linear even with the most dynamic material. The low profile damped polymer cone with a rubber surround minimizes cone resonance and breakup for a smooth high-frequency roll-off to create an easy transition to a tweeter. Morel's high flux dual magnet motor system focuses the magnetic field on the voice coil gap to ensure precise control even when driven to the limits of excursion. Finally, with extensive venting through the motor and frame, the KW-1 can dissipate plenty of heat, limiting compression even at high output for extended periods.
Engineered to deliver premium performance in a compact design, the Morel KT-1 1-1/8" soft dome compact tweeter is a perfect match for the woofer. The lightweight 1-1/8" damped fabric dome nearly eliminates unwanted resonances for incredibly flat response from 2,000 to 20,000 Hz, even up to 30° off-axis. A powerful optimized neodymium motor precisely controls the voice coil and diaphragm for low distortion and incredible detail. With a large copper voice coil and aluminum former, the KT-1 can handle up to 80 watts RMS to produce more output than you would expect from a tweeter this small. At only 3" diameter, the center to center distance between the tweeter and woofer/midrange can be kept at a minimum for a seamless transition at the crossover frequency. The KT-1 will provide all of the performance and natural sound you have come to expect from Morel.
About the Enclosure
The locally sourced 3/4" MDF enclosure panels are all CNC milled for tight tolerances ensuring easy enclosure assembly. The vented enclosure is optimized to give extended low-frequency response while controlling excursion to allow high output and power handling. For rigidity, the compact enclosure uses a brace assembly that ties the front, back, top, bottom, and sides together to make for an extremely solid structure that virtually eliminates cabinet resonances. All double rabbeted and dadoed joints make assembly almost effortless, requiring only a few small clamps for a perfect fit. Recesses for flush mounting the tweeter, woofer, and port are pre-cut, making installation a snap.
Note: This kit comes with nearly everything required to build a single Ardon speaker. Including: Knock-down enclosure, drivers, crossover components, binding posts, screws, and wire
• Power handling: 100 watts RMS/200 watts max
• Frequency response: ±3 dB from 65-19,000 Hz (±6 dB from 40- 20,000 Hz)
• Impedance: 4 ohms
• Sensitivity: 85 dB 1W/1m
• Dimensions: 12" H x 8.5" W x 12.75" D
Note: Crossover components may be substituted with parts of equal or higher quality depending on available inventory.
Part Number300-7144
UPC848864066707
Weight29.59
Cabinet Dimensions (HxWxD)12" x 8.5" x 12.75"
Cabinet OptionsUnfinished/Unassembled
ColorUnfinished
Configuration2-way
Input Rating100
Speaker TypeBookshelf
Woofer Diameter6"
