  • MB Quart 95-7119 1" Titanium Dome Tweeter with Truncated Faceplate 6 Ohm
CLEARANCE MB Quart 95-7119 1" Titanium Dome Tweeter with Truncated Faceplate 6 Ohm
Factory Buyouts
Part #279-466
Factory Buyouts
Part #279-466
Model: 95-7119
Made in Germany by MB Quart, the new old stock 95 7119 1" titanium dome tweeter was originally manufactured for a high end speaker system. With a rigid titanium dome and rubber surround, this tweeter will deliver accurate response with incredible detail. A heavily damped pole vent and rear chamber lowers Fs and resonances for flat response and lower crossover capability. The unique truncated on one side faceplate is perfect for minimizing the center to center distance to a midrange in MT or 3-way designs.
  • Titanium diaphragm for extended high frequency response with minimal dome breakup
  • Secondary bucking magnet concentrates magnetic field in the gap for improved efficiency
  • Damped pole and rear chamber lowers Fs and minimizes unwanted resonances
  • Faceplate is truncated on one side for minimizing center to center distances
  • Mesh grill protects dome from foreign objects and curious fingers
  • Rubber surround improves damping to help control dome breakup
The new old stock 95 7119 is a 1" titanium dome tweeter which was manufactured in Germany by MB Quart, who was always known for producing extremely high quality drivers, especially high frequency drivers. This tweeter features a unique truncated on one side faceplate that is perfect for lowering center to center distance to a midrange in 2-way MT and 3-way designs. The solid titanium dome's low weight and rigid structure ensures accurate response to well above the capability of the human ear. Keeping unwanted resonances under control, a rubber surround supports the 1" titanium dome to eliminate the harshness that is sometimes associated with metal dome tweeters. A damped pole vent and rear chamber pushes the Fs down to 860 Hz giving this tweeter the ability to handle low crossover frequencies for easy transition to a midrange driver. The 95 7118 also features a secondary bucking magnet which concentrates the magnetic field on the voice coil gap improving efficiency and overall out capability. Finally, the stylish reinforced plastic faceplate includes an integrated perforated steel grill to protect the fragile dome for years of worry free operation.
Limited quantities! Get these classic tweeters from MB Quart while they are still available. After they are gone you may never see them on the market again.
BrandFactory Buyouts
Model95-7119
Part Number279-466
UPC848864062181
Weight1.45
Cone / Dome Diameter1"
Cutout Diameter2.875
Tweeter TypeMetal Dome
Power Handling (RMS)40 Watts
Frequency Response2,000 to 20,000Hz
Sensitivity90dB 2.83V/1m
Resonant Frequency (Fs)860Hz
DC Resistance (Re)5.47Ω
Voice Coil Inductance (Le)1.9mH
Mechanical Q (Qms)1.65
Electromagnetic Q (Qes)1.13
Total Q (Qts)0.67
Overall Outside Diameter3.8125"
Depth2"
