CLEARANCE WONDOM Lithium Polymer 503040 Flat Battery 3.7V 600mAh 5 x 30 x 42mm with Plug
- PCM over/under charge protection built-in for safety
- Only 0.2" thick enables it to fit into smaller projects where space is limited
- 600mAh rating powers most 4-5 VDC projects
- JST XH 2.54 2-pin plug for easy installation
15In Stock
We'll send you an email when WONDOM Lithium Polymer 503040 Flat Battery 3.7V 600mAh 5 x 30 x 42mm with Plug is back in stock or available for preorder.
