  • Lepai LWP-250 2 x 50W Outdoor/Marine ATV Golf Cart Motorcycle Waterproof Bluetooth 5.0 Mini Amplifier with Mounting Flanges
Lepai
Part #310-3050
Lepai
Part #310-3050
Model: LWP-250
Lepai has once again exceeded expectations with their latest offering - a remarkable Bluetooth 5.0 mini IP67 waterproof amplifier. This compact marvel is so small that it can be mounted practically anywhere you can imagine. From motorcycles to golf carts, ATVs to boats, and even backyard pool areas or porches, the sound quality delivered by this amplifier is truly astonishing given its size.
  • Wide 9 to 24 VDC working input voltage range, plus it accepts 12 VAC so it will work with most landscape lighting installations
  • IP67 waterproof rating for marine applications or other wet environments
  • All sealed electrical components that withstand the G-forces that off road vehicles dish out
  • Mounting flanges for permanent installations
  • Includes four mounting screws and six silicon filled, waterproof wire nuts for quick installation in harsh environments
  • Built-in external antenna for up to 50 ft. Bluetooth 5.0 wireless range
  • CE and FCC certified
Your Price: $23.98
Order in the next 1 hr 10 min to ship today. Details
Bluetooth and Waterproof Team Together
Experience the seamless wireless connectivity of Bluetooth 5.0 technology and elevate your music streaming to a whole new level. With this advanced technology, you can effortlessly connect and stream your favorite tunes from any compatible device. Say goodbye to tangled wires and enjoy the freedom of wireless music like never before.
But that's not all. We understand that you want to enjoy your music outside without worrying about water damage. That's why the Lepai LWP-250 comes with an impressive IP67 waterproof rating. This enables you to add music to landscaping plans. The LWP-250 requires 12 to 24 VDC or 12 VAC which is the same voltage that most landscape lighting uses. No more sacrificing your music enjoyment for fear of water damage – now you can have the best of both worlds.
All Terrain Music
The LWP-250's all solid state components sealed inside a durable metal shell takes a beating. Imagine cruising across the lake in a boat, riding down the open road on your motorcycle, or exploring rugged terrains in your ATV, all while enjoying a crystal-clear sound experience.
Compliment Your Outdoor Setting
Picture yourself hosting a poolside party, relaxing on your patio, or checking out the scenery from your deck, with the perfect soundtrack enhancing your every moment. With this mini amplifier, these scenarios become a reality.
More Watts/Inch
Don't be fooled by its size - this 4.33" x 1.9" x 1" amplifier packs a punch. Its 2 x 50W and impressive sound quality will leave you amazed and your friends impressed. Lepai has truly outdone themselves with this incredible product.
Versatility and Quality sound on a Budget
Lepai has managed to create a product that not only sounds great in almost any environment, but also fits within budget constraints. So, whether you're an adventure seeker, a music lover, or simply someone who appreciates great sound, don't miss out on this opportunity to elevate your audio experience. Grab the Lepai LWP-250 Bluetooth 5.0 mini IP67 waterproof amplifier today and prepare to be blown away by its exceptional performance.
Specifications: • Power output: 50 watts x 2 @ 6 ohms 24 VDC • Frequency response: 20 Hz-20,000 kHz +/- 3% • Conversion efficiency: >82% • Impedance: 4-8 ohms • Amplifier input voltage: 12-24 VDC, 12 VAC • Amplifier input amperage: 4A • Amplifier topology: Class D • Bluetooth range: Up to 50 feet • Bluetooth 5.0 • Bluetooth name: Lepai LWP-250 • Dimensions with mounting flanges: 4.33" W x 1.9" D x 1" H (110 x 48 x 25 mm)• Mounting screw spacing manual correction: 4.05" and 1.42" (103 x 36 mm) to center.
BrandLepai
ModelLWP-250
Part Number310-3050
UPC848864072623
Weight0.6
Power (RMS/Channel 8 ohms)0 - 25 Watts
Special FeaturesBluetooth Wireless
