  • Lepai 2.1 2x40W Amplifier LP-168HA without Power Supply
CLEARANCE Lepai 2.1 2x40W Amplifier LP-168HA without Power Supply
Lepai
Part #310-3081
Lepai
Part #310-3081
Looking for a simple 2.1 amplifier? The Lepai LP-168HA offers audio power output for a pair of stereo speakers, along with a dedicated subwoofer output. Perfect for computer sound systems!
  • Perfect amplifier for computer desks
  • Stereo speaker and dedicated subwoofer amplifier
  • Rear-mounted USB charging port
  • Bass, treble, and subwoofer crossover controls
  • Stereo RCA and stereo 3.5 mm inputs
CLEARANCE $24.98
MSRP: $49.99
Save $25.01 (50%)
Order in the next 2 hr 43 min to ship today. Details
366In Stock
Lepai's LP-168HA 2.1 amplifier is the perfect computer partner—it provides up to 40 watts of power output to stereo speakers, in combination with a dedicated subwoofer output capable of up to 68 watts of amplifier output. To connect a subwoofer simply hook them up to either the left pair or right pair of bottom row spring terminals; both will work as they are wired in parallel.
Bass, treble, and volume controls on the front of the amplifier let you adjust your music for the best possible sound from your stereo speakers. The discrete subwoofer output is controlled separately from the stereo volume output, with controls for level adjustment and crossover adjustment found on the amplifier's face.
Audio source connectivity is provided via a front-mounted stereo 3.5 mm jack, or a stereo pair of RCA jacks on the rear of the amplifier. A rear-mounted USB port enables charging of devices such as smartphones and MP3 players. The wide input voltage range of 9 to 15 VDC allows the LP-168HA to be used in automotive or mobile applications.
• Stereo power output: 2 x 40W max (power output dependent upon power supply)
• Subwoofer power output: 1 x 68W max (power output dependent upon power supply)
• Power requirements: 9 to 15 VDC, 3A (minimum)
• DC power input jack: 2.1 mm x 5.5 mm
• Minimum load: 2 ohms
• Minimum THD: <1%
• Signal-to-noise ratio: >80 dB
• Frequency response: 20-20,000 Hz
• Adjustable subwoofer crossover: 50-200 Hz
Dimensions (including mounting flange): 7" W x 4" L x 1-3/4" H.
Note: Power Supply Not Included. Power supply requirements are 9 to 15 VDC, 3A with a 2.1 mm x 5.5 mm tip. Center positive. We recommend the 120-057 15 VDC, 4A power supply.
BrandLepai
Part Number310-3081
UPC848864067421
Weight0.95
Special FeaturesUSB Connectivity
