  • Lavolta 3CL40BK 40-Piece RGB 5050 SMD 3 LED Black Module IP67 Waterproof 18 ft. Light Strip Kit
CLEARANCE Lavolta 3CL40BK 40-Piece RGB 5050 SMD 3 LED Black Module IP67 Waterproof 18 ft. Light Strip Kit
Lavolta
Part #073-136
Lavolta
Part #073-136
Model: 3CL40BK
Create your own light effects with Lavolta's IP67 waterproof rated RGB LED light strip module kit that mounts almost anywhere. Peel and stick adhesive or a screw hole on each side of the three LED modules keep the lights in place on a boat, under your deck railing, around windows, under cabinets, or behind a sign for backlighting.
  • Aggressive adhesive peel and stick wide strips on each module for quick mounting
  • A hole on each side of the module provides a lasting hold with optional screws
  • 2.7" flexible 4-conductor wire separates each 3 RGB LED module for adjustable mounting
  • 40 modules have the ability to stay stuck together for back lighting signs or separate for an 18 ft. run
  • IP 67 waterproof rating and 12 VDC power requirement make the LED modules ideal for use on watercrafts and off-road vehicles
  • Kit includes controller with IR remote and a 12 VDC 3A UL certified 5 ft. AC adapter
CLEARANCE $29.00
MSRP: $56.99
Save $27.99 (49%)
141In Stock
Light up a boat, deck, window or house frame with these Lavolta 3 RGB LED IP67 40 light module strips. 2.7" of wire separates each module making it easy to go around corners or making strip length modifications. A screw hole on each of the module keeps the LEDs firmly in place without any sagging or falling off over time. Strong adhesive double sided stick tape securely attaches each module to various surfaces for quick installation.
Keep the modules stuck together and make a bright, multi-color light block for under a cabinet or to backlight a sign. The modules have the ability to form shapes by bending the 2.7" four conductor wire that separate them. Use the included controller with IR remote to change colors, dim, or to provide a flashing light show.
Specifications: • LED Type: 5050 SMD LED by Epistar • Viewing Angle: 120° • Luminous Flux (lm): Red 17 lm, green 38 lm, blue 10 lm • LED Qty./module: 3 Pcs. • Working voltage: 12 VDC • Consumption/module: 0.72W • Shell: Black UL 94V0 ABS • Working temperature: -4° to 140° F • Idle temperature: -58° to 176° F • LED modules IP degree: IP67 • Certifications: CE and RoHS • Module dimensions: 2.68" L x 0.77" H x 0.23" D • Wire length between modules: 2.7"
BrandLavolta
Model3CL40BK
Part Number073-136
UPC848864043500
Weight1.45
