CLEARANCE Speaker L-Pad Attenuator 15W Stereo 1" Shaft 8 Ohm
Part #260-251
Part #260-251
L-pads adjust the relative volume of drivers connected to them by placing added resistance in series and parallel, keeping impedance a constant 8 ohm load. This stereo L-pad is rated at 15 watts RMS and is designed to be used with two 8 ohm loads. Features a 1" shaft length. Comes with mounting hardware, faceplate, and knob.
- Easy level adjustment of two 8 ohm loads without changing impedance
- Great for speaker design tweaking
- Maintains constant 8 ohm impedance
- Mounting hardware included
We'll send you an email when Speaker L-Pad Attenuator 15W Stereo 1" Shaft 8 Ohm is back in stock or available for preorder.
