  • Jensen Iso-Max SP-2SX 2 Channel speakON Speaker Level to XLR Line Level Converter Adapter
Jensen Transformers
Part #246-0131
Jensen Transformers
Part #246-0131
Model: SP-2SX
Jensen's Iso-Max isolators use the world's best transformers to solve problems common to pro audio, home theater, car audio, and audiophiles alike. The SP-2SX is a two channel isolator which converts speaker level signals (up to 750W) to +4 dBu balanced line level.
  • Converts amplified signal up to 750W to balanced line level XLR
  • Built using the finest transformers money can buy: Jensen
  • Passive design means no power or batteries needed
  • Eliminates ground loop hum and noise
Your Price: $449.99
MSRP: $494.99
Save $45.00 (9%)
Order in the next 3 hr 17 min to ship today. Details
7In Stock
The SP-2SX is used to convert speaker level signals from speakON connectors to balanced +4 dBu line level XLR. Ideal for expanding existing distributed audio systems, the SP-2SX has DIP switches to let you adjust for 25, 75, 250 or 750 watt power level, even 25V and 70V commercial amps may be converted. Your converted signal will be clean, and free from noise, hum, or distortion due to the use of high quality components and Jensen transformers.
We've all been there before. You spend hard-earned money and hours of your time selecting just the right components and putting together a great sound system. You get everything hooked up, plug it in and fire it up and BAM! That dastardly hum rears its ugly head. It's not just an audiophile issue. It happens anywhere you might want to install high quality sound. Home theater, mobile audio, pro audio and commercial sound systems can all be plagued by this most vile and wretched affliction.
Lucky for you, Jensen has introduced solutions for virtually any type of setup in which you might encounter this pernicious foe. Using world-renowned Jensen transformers, the Iso-Max line of products kills the hum without killing your sound quality. Simply insert the Iso-Max unit into your signal path, and voilà! Hum is out, and clean luscious sound is all that's left. Enjoy!
Specifications: Frequency response: < 5 - 40,000 Hz • Connectors: RCA and RJ45 • Max signal handling: up to 750 watts • CMRR noise rejection: 95 dB @ 60 Hz • Dimensions: 6.94" x 3.5" x 1.71".
BrandJensen Transformers
ModelSP-2SX
Part Number246-0131
UPC676101041725
Weight1.9
