  • Jantzen Audio 5.6uF 400V Standard Z-Cap Crossover Capacitor
Jantzen Audio
Part #027-276
Jantzen Audio
Part #027-276
Model: 001-0437
Jantzen Audio Standard Series capacitors are constructed of metallized polypropylene, especially manufactured for audio application. The materials used are carefully chosen for the best sonic performance. Finally, an affordable state-of-the-art capacitor!
  • Dimensions: 21mm x 31mm
  • A high quality entry level audiophile-grade capacitor
  • Tin plated oxygen free copper leads
Your Price: $6.69
MSRP: $8.99
Save $2.30 (26%)
Quantity:Qty: 1-9 $6.69/ea
Quantity:Qty: 10+$6.13/ea
Estimated back in stock 2/21/2025
Alert Me When Available
Product Features
  • Dimensions: (Ø 21mm - L: 31mm)
  • The Standard-Z Cap is our entry level audiophile capacitor.
  • It is a single foil standard type MKP capacitor that uses the highest possible quality aluminum based metalized PP foil.
  • It uses the same foil as our Superior- and Silver Z-caps, but in this application as a single foil capacitor.
  • The Superior – and Silver Z-caps are double foil (“Super MKP”) constructions where two capacitors are essentially wound into to one housing.
  • A capacitor that offers great sound and performance within its class.
  • Fast reacting, smooth and detailed in sound, compared to other single foil PP capacitors.
Technical Data
  • Capacitor foil: Polypropylene foil metalized with Aluminum (Al)
  • Type: Non-polarized MKP (single foil lane)
  • Construction: Round tubular type axial leads
  • Coating: Blue plastic tape wrapped and sealed in black resin
  • Leads: Tin plated oxygen free copper
  • Capacitance Range: 400VDC from 1.0 μF to 100μF
  • Capacitance tolerance: ±5% (on nominal value)
  • Dielectric absorption factor: <0.5% @ 20℃
  • Dielectric thickness: PB=5µm
  • Self-inductance: < 15 nH
  • Insulation resistance: >100.000 MΩ @ 20℃
  • Temperature coefficient: -200℃ x 10-6/℃
  • Temperature Range: -55℃t o +85℃
  • Metal layer thickness: PB=0.3µm
  • Metal layer conductivity: PB =1.2 Ω/cm2
BrandJantzen Audio
Model001-0437
Part Number027-276
UPC844632061790
Capacitance5.6 uF
Tolerance5%
Voltage Rating400V
MONSTER DEAL
OF THE WEEK
$14.98 EACH
SAVE 25%
Dayton Audio Boost Mini Portable Bluetooth Speaker Black
