Jantzen Audio 100uF 400 V Cross Cap Crossover Capacitor
Jantzen Audio
Part #027-956
Jantzen Audio
Part #027-956
Model: 001-0290
0.1uf0.12uf0.15uf0.18uf0.22uf0.27uf0.30uf0.33uf0.39uf0.43uf0.47uf0.50uf0.51uf0.56uf0.82uf1.0uf1.10uf1.2uf1.5uf1.6uf1.8uf2.0uf2.2uf2.4uf2.7uf3.0uf3.3uf3.6uf3.9uf4.1uf4.3uf4.5uf4.7uf5.1uf5.4uf5.6uf6.2uf6.8uf7.5uf8.2uf9.1uf10uf12uf15uf16uf18uf20uf22uf25uf27uf30uf33uf36uf39uf47uf51uf56uf68uf82uf100uf120uf150uf220uf270uf300uf330uf390uf
Jantzen Audio Cross Caps are built from ultra-high-quality metallized film and provide superb sonic accuracy and detail for any audio application. 400 VDC rating is excellent for crossover networks, allowing the capacitors to flawlessly handle large current peaks without distortion.
- Dimensions: 59mm x 58mm
- Virtually free of distortion with a neutral sonic profile
- Rated Voltage: 400 VDC / 250 VAC
- A tolerance of ±5% (on nominal value)
