  • JBL Selenium D350 2" 200 Watt Bolt-On Compression Driver 8 Ohm
SeleniumPart # 264-485
Model: D350
The JBL Selenium D350 is a high-performance 2" compression driver that delivers superior audio clarity and power. Designed to output high sound pressure levels, this driver is perfect for professional sound systems.
  • Exceptional audio clarity and detail
  • A phenolic dome diaphragm means low distortion and high efficiency
  • Designed for clarity and precision in both mid and high ranges
  • Easy and available diaphragm replacement to keep your driver in top condition
Your Price: $209.99
We'll send you an email when JBL Selenium D350 2" 200 Watt Bolt-On Compression Driver 8 Ohm is back in stock or available for preorder.
Order in the next 4 hr 18 min to ship today. Details
The JBL Selenium D350 is a high-performance 2" compression driver that provides superior audio clarity and power, making it ideal for professional sound systems. The bolt-on design means secure and easy installation that will hold up to use on the road. With an impressive 200-watt continuous power rating, the D350 handles high-power applications while maintaining clear, powerful sound, perfect for large venues and demanding audio environments. Engineered for exceptional audio clarity, the D350 minimizes distortion, delivering crisp and articulate sound across a wide frequency range. Its durable construction will allow it to withstand frequent use, making it a reliable, long-lasting choice for high-performing audio systems.
Specifications: • Power handling: 200 watts RMS/400 watts max • Throat diameter: 2" • Impedance: 8 ohms • Frequency response: 600-7,600 Hz • SPL: 110 dB 2.83V/1m • Magnet weight: 41 oz. • Dimensions: Overall diameter: 6.1" • Depth: 3.03"
BrandSelenium
ModelD350
Part Number264-485
UPC7896359542079
Weight8
Mounting Type4-Bolt
Power Handling (RMS)200 Watts
