  • JBL Selenium HL14-50N 2" Exponential Horn 45x45 4-Bolt
Selenium
Part #264-316
Selenium
Part #264-316
Model: HL14-50
The HL14-50N is a compact 2" conical horn that delivers narrow 45° x 45° dispersion output down to 600 Hz making it a great choice for stage monitors, side fill, and general PA use.
  • Compact size and flat front is ideal for use in tight spaces
  • Notched sides for close center to center spacing in MTM arrangements
  • Rugged aluminum construction will handle plenty of abuse
  • Narrow dispersion to minimize unwanted reflections
Your Price: $31.99
MSRP: $47.99
Save $16.00 (33%)
JBL Selenium's HL14-50N conical horn uses a compact design allowing for close driver spacing needed for small high output speakers such as stage monitors. The narrow 45° x 45° dispersion is perfect for minimizing floor and wall reflections while providing a surprisingly long throw for such a small horn. In addition, this horn will load frequencies down to 600 Hz making it an easy match for many large woofers.
Specifications: • Horn Type: Exponential • Minimum Frequency: 600 Hz • Nominal Dispersion: 45° H x 45° V • Throat Diameter: 2.0" • Mounting Type: 4 hole • Dimensions: 6.5" W (6.25" inside notches) x 6.9" H x 5.25" D • Selenium #HL14-50N.
BrandSelenium
ModelHL14-50
Part Number264-316
Weight1.95
ConstructionAluminum
Entry / Throat Diameter2"
Mounting Type4-Bolt
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
