  • In-Wall Stereo Audio and Bluetooth Receiver Wall Plate with Volume Control
Part #183-341
Part #183-341
Turn any set of active / amplified speakers into Bluetooth ready speakers with the Bluetooth audio wall plate. Featuring a 3.5mm auxiliary connection, the wall plate also is able to pass signal via a wired connection. The unit is easily mountable onto a 1 gang opening.
  • Turns any set of active / amplified speakers into Bluetooth capable speakers
  • 3.5mm stereo audio output allows for connection to any powered speaker
  • 3.5mm auxiliary port for plugging in wired connections
  • Volume control for quick output level changes
  • Mounts onto a 1 gang opening
  • 5 VDC 1A power adapter included
Your Price: $59.98
MSRP: $79.99
Save $20.01 (25%)
Ultimate Bluetooth Flexibility
The Bluetooth audio wall plate allows for connecting audio devices to any set of speakers using Bluetooth. The unit mounts onto a 1 gang opening for an easy installation. The front plate also features a 3.5mm auxiliary port to plug in your devices if a wired connection is preferred. Manual volume control enables you to quickly change the output level. The Bluetooth wall plate includes a 5 VDC 1A power supply for quick installation.
  • Ports: Front: 3.5mm input, Bluetooth pairing button, volume control, Back: 3.5mm output, 3.5mm input, 5 VDC power in, terminal
  • LED: Bluetooth status, power
  • Color: White
  • Board dimensions: 1-13/16" D x 2-3/4" W x 5/8" H (46 x 70 x 16 mm)
Note: Bluetooth name is Music BT with security code 0000.
Part Number183-341
UPC848864071664
Weight0.45
Board TypePreamp
Special FeaturesBluetooth / Wireless-Volume Control
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
