  • ICEpower 200AS1 Class D Audio Amplifier with Power Supply Module
NEW ICEpower 200AS1 Class D Audio Amplifier with Power Supply Module
ICEpower
Part #326-271
ICEpower
Part #326-271
ICEpower 200AS1 all-in-one class D amp and Energy Star compliant power supply module produces an amazing 1 x 200W RMS @ 1% THD. 200AS1's small size and fanless design makes it perfect for DIY audio projects such as amplifiers, active speakers, subwoofers, studio monitors as well as single channel guitar or bass amplifiers.
  • Very rugged, 70g shock tested design for professional use
  • Built-in circuits for shorts, over-current, and thermal protection
  • No noisy fan needed
  • High current output stages, designed to comfortably drive any speaker load from 3.5 ohms and up
  • Perfect size and wattage for active bookshelf, computer, studio monitor, or satellite home theater speakers
  • Power saving ErP universal mains and Energy Star compliant power supply
  • EMC and safety pre-approved enabling fast design-in for finished audio components
NEW $129.98
All-In-One High Wattage Fanless AMP & Power Supply Board
The 200AS1 sets a new industry benchmark in audio performance, efficiency, and power density, made possible by adapting the very latest ICEpower technological advances. Its mini size foot print, 1 x 200W, built-in power supply and fanless design creates limitless possibilities for single channel active speakers or amplifier creations that pack-a-punch.
Guitar Amps and Powered Subwoofers
ICEpower has made a significant mark in the audio industry, powering a variety of name brand guitar amplifiers and subwoofers that professionals trust for their reliability and performance. One standout product is the ICEpower 200AS1 amp module, known for its impressive ability to withstand a shock test of 70g lasting 12ms. This ruggedness makes it an excellent choice for traveling musicians who need durable equipment that can handle the rigors of life on the road.
 If you’re already drawn to the reliability of ICEpower amp modules, why not take the next step and create your own custom guitar amp or powered subwoofer using the 200AS1? Building your own speaker enables you to tailor the sound to your unique preferences and performance needs. Plus, assembling your own gear deepens your understanding of audio technology and enriches your connection to your music.
Studio Monitors
ICEpower 200AS1 is a fantastic choice for making your own studio monitors, and for very good reasons. Their innovative, cool-running small size combination power supply amp board design makes it ideal for high-powered applications where performance and reliability are paramount. Many traditional high-wattage amplifiers require a large transformer and a fan to keep the combination from overheating. The 200AS1 utilizes advanced ICEpower Class D chip technology and a small transformer to deliver impressive power output while generating significantly less heat.
 This means you won't have to worry about the distracting noise of a fan in the background while you work on your recording projects. The quiet operation allows for a more immersive and focused listening experience, which is crucial when you're mixing and mastering audio.
Live Sound and Home Theater
ICEpower Audio Products are at the forefront of audio technology, delivering exceptional sound quality that enhances both live performances and home listening experiences. Whether you're enjoying a local band at your favorite pub or attending a grand music festival, ICEpower amplifiers play a crucial role in ensuring that every note is delivered with clarity and power.
These advanced audio solutions are not just limited to large venues; they also bring excellence into personal spaces. ICEpower technology drives a variety of products, including high-fidelity home theater amplifiers, subwoofers, active speakers, and wireless speakers. This versatility means that you can enjoy professional-grade sound quality right in the comfort of your own home.
The commitment to quality and innovation from ICEpower is truly inspiring. By incorporating 200AS1 into your next audio project, you support an industry that values excellence in sound, enriching both public events and personal experiences. So, whether you’re looking to build a powered speaker or amplifier, ICEpower is a reliable choice that encourages a passion for music and entertainment. Embrace the power of great sound—it's a journey worth taking!
To get started building your project use the wiring harness kit listed below. Each cable plugs into a designated spot shown in the Connection Diagram. The Data Sheet under Manuals and Resources guides you through each wires function.
Note:Requires the 326-192 ICEpower Amplifier Module 100AS1 Wiring Harness Kitfor full stand-alone functionality (sold separately).
ICEpower power supply amp boards are only available in the USA from Parts Express. Parts Express ships out each order the same day if placed before 4 pm EST M-F. This makes it easier than ever to acquire ICEpower amp modules for your projects, and continental USA DIYs and OEMs save money by eliminating international shipping cost.
Specifications: • Power output: 1 x 210W RMS @ 4 ohms 1% THD+N, 1 kHz • Frequency response: 20-20,000 Hz • Dynamic range: 110 dB A-weighted • Total efficiency: 78% @ 200W, 4 ohm • Unregulated auxiliary power supply: +/- 15 to +/- 20.5 VDC @ 200 mA • Input voltage: 100~240 VAC 50/60 Hz • Maximum output current limit: 13A • GeForce rating: 70g • Dimensions: 5.51" W x 3.03" D x 1.44" H (140 x 77 x 36.5 mm).
BrandICEpower
Model200AS1
Part Number326-271
UPC848864079301
Weight0.81
Board Type1 Channel Mono Amp
Power (RMS/Channel 8 ohms)101 - 250 Watts
