  • ICEpower 1000A Class D Audio Amplifier Module 1 x 1000W
CLEARANCE ICEpower 1000A Class D Audio Amplifier Module 1 x 1000W
ICEpower
Part #326-202
ICEpower
Part #326-202
Model: 1000A
Easily add the ICEpower 1000A to the 1000ASP ICEpower amp boards to create an active 2 or 3-way professional speaker or stereo amplifier. It gets its DC power from the 1000ASP amp board eliminating the need for an extra power supply.
  • Rugged 70g construction for durability
  • Soft start-up and mute/de-mute eliminates popping noises
  • Under-voltage protection for longevity
  • Standby mode for quick power-up
  • Pre-approved for Safety, EMC and RoHS compliance
  • Balanced input and output
  • Quiet fan less design
Add the 1000A amp module to 1000ASP ICEpower amp boards to create an active 2-way speaker system. The 1000A amp module's 20-1,000 Mhz frequency response makes it the perfect amp for a subwoofer or woofer in a 2-way or 3-way powered speaker design. This enables each speaker in the system to have its own amplifier verses sharing power with a single amplifier. The 1000A will get 120 VDC from the 1000ASP amp board to deliver 1,000 watts RMS at 4-ohms and even more with 2-ohm stability.
Note:Requires the 326-146 ICEpower Amplifier Module 1000A Wiring Harness Kitto attach to the 1000ASP amp board (sold separately).
Like the ASP series, the ICEpower 1000A withstands 70 G-force shock to each side of the board. This along with the under-voltage and thermal protection ensure long life under live concert conditions. Make a high power, fanless stereo amp, or 2-way powered speaker by adding this amp board to the 1000ASP.
ICEpower amp board modules are only available in the USA from Parts Express. Parts Express ships out each order the same day if placed before 4 pm EST M-F. This helps repair shops give quicker and more accurate estimate times when ordering ICEpower replacement boards, and makes it easier than ever to acquire ICEpower amp modules for your projects. Continental USA DIYs, OEMs, and repair shops also save money by eliminating international shipping cost.
Specifications: • Wattage output: 1000W RMS @ 4 ohms 0.04% THD+N, 1 kHz • Frequency response: 20-1,000 Hz, all loads • Dynamic range: 120 dBA • Total efficiency: 93% @ 500W, 8 ohms • Input voltage: 120 VDC • Dimensions: 4" W x 3.55" D x 1.03" H.
BrandICEpower
Model1000A
Part Number326-202
UPC848864053783
Weight0.8
Board Type1 Channel Mono Amp
Power (RMS/Channel 8 ohms)501+ Watts
