  • Hose Clip/Solder Aid Pliers with Expansion Lock
CLEARANCE Hose Clip/Solder Aid Pliers with Expansion Lock
Part #360-031
Part #360-031
Use the solder plyer tool to free up both hands when working under vehicle dashes or in tight places. It's locking handle also works great for removing spring hose clamps.
  • Rubber covered 1" x 1" handles provide extra grip and keeps hands cool while soldering
  • Works great in tight places where other helping hand tools won't work
  • Spring tips hold wires in place freeing up both hands
  • 10" x 2" x 1" with the handle squeezed together size for large gauge wires and hose clamps
CLEARANCE $9.90
MSRP: $25.99
Save $16.09 (62%)
Order in the next 3 hr 42 min to ship today. Details
148In Stock
Solder helping hand tools work great if you have a nice flat surface to set them on. These solder pliers will come to your rescue when flat surfaces aren't available. Working on vehicles under the hood or under the dash is the perfect scenario where you need these solder pliers. Place wires that need to be soldered in each of the opposing spring tips to free up one or both hands. The locking handle keeps the wires from spreading apart, but doesn't keep the wires from getting closer together. So don't squeeze the handle once the wires are in soldering position.
This dual-purpose tool also works perfect for removing spring hose clamps. Using regular pliers to remove a spring hose clamp presents many issues. You have to constantly squeeze the handle while working the hose clamp off the hose. Usually, the pliers slip off before the hose clamp comes off. The solder/hose clamp pliers handle locks into place enabling you to concentrate on sliding the hose clamp off. Using this tool helps you prevent damaging the spring hose clamp enabling you to use it again when you replace the hose.
Part Number360-031
UPC848864068046
Weight0.6
