  • HiVi F8 8" Bass/Midrange
HiVi
Part #297-445
HiVi
Part #297-445
Model: F8
The HiVi F8 woofer utilizes a Kevlar and paper composite cone that has lower weight, higher rigidity, and an improved damping factor.
  • Kevlar/paper cone
  • Die-cast basket
  • High loss rubber surround
Your Price: $69.98
MSRP: $99.99
Save $30.01 (30%)
Quantity:Qty: 1-3 $69.98/ea
Quantity:Qty: 4-9 $66.95/ea
Quantity:Qty: 10+$63.92/ea
Order in the next 2 hr 40 min to ship today. Details
Only 4 In Stock
More due any day
The HiVi F8 woofer utilizes a Kevlar and paper composite cone that has lower weight, higher rigidity, and an improved damping factor. The back of the cone is hand coated with damping compound to further maximize performance stability and control of resonances. Midrange clarity and tonal balance are remarkable. The F8 has been optimized for dynamic low bass reproduction in compact or medium vented enclosures. The driver employs a vented Kapton voice coil former and flat spider to avoid air compression and ensure maximum power handling. A massive aluminum die-cast basket has been developed to minimize structural resonances, and a shielded magnet structure enables the F8 to be incorporated easily into audio/video speaker applications. The F8 has an exceptionally smooth frequency response (within +/-1.7 dB tolerance in 70-3,000 Hz range, measured on an IEC baffle), which helps make the driver a perfect choice for high resolution 2-way or 3-way systems. Recommended crossover frequency for a two-way system design is 1.8-2.2 kHz.
BrandHiVi
ModelF8
Part Number297-445
UPC844632021312
Weight7.53
Nominal Diameter8"
Power Handling (RMS)60 Watts
Power Handling (MAX)120 Watts
Frequency Response37 to 3,000Hz
Sensitivity88dB 2.83V/1m
Voice Coil Diameter1.375"
Resonant Frequency (Fs)37Hz
DC Resistance (Re)6.5Ω
Mechanical Q (Qms)4.71
Electromagnetic Q (Qes)0.44
Total Q (Qts)0.4
Compliance Equivalent Volume (Vas)1.37ft³
Mechanical Compliance of Suspension (Cms)0.59mm/N
Diaphragm Mass Inc. Airload (Mms)30.5g
Surface Area of Cone (Sd)214cm²
Cone MaterialPaper / Kevlar
Overall Outside Diameter9.44"
Baffle Cutout Diameter7.156"
Depth4.55"
# Mounting Holes12
Sealed Volume0.63ft³
Sealed F353.4Hz
Vented Volume1.2ft³
Vented F338.3Hz
