  • HiVi B1S 1" Shielded Aluminum Mid/Tweeter
HiVi
Part #297-411
HiVi
Part #297-411
Model: B1S
The B1S full-range speaker has a polymer frame and foam surround. Its magnetically shielded design allows use in center channel and other nearfield multimedia applications.
  • Magnesium/aluminum alloy concave cone
  • Shielded design allows use in center channel and other nearfield multimedia applications
  • Polymer frame and foam surround
Your Price: $8.98
MSRP: $11.99
Save $3.01 (25%)
Quantity:Qty: 1-3 $8.98/ea
Quantity:Qty: 4-9 $8.53/ea
Quantity:Qty: 10+$8.08/ea
Order in the next 7 hr 7 min to ship today. Details
2145In Stock
Magnesium/aluminum alloy concave cones and square frames are the distinguishing features of the HiVi BS series. The B1S full-range speaker has a polymer frame and foam surround. Its magnetically shielded design allows use in center channel and other nearfield multimedia applications. These drivers are capable of covering a wide portion of the audio spectrum, and are easy to install without the need for cutting complicated driver recesses.
BrandHiVi
ModelB1S
Part Number297-411
UPC844632022975
Weight0.06
Nominal Diameter1"
Power Handling (RMS)1 Watts
Power Handling (MAX)2 Watts
Frequency Response250 to 20,000Hz
Sensitivity79dB 2.83V/1m
Voice Coil Diameter0.75"
Resonant Frequency (Fs)220Hz
DC Resistance (Re)6.5Ω
Mechanical Q (Qms)2.57
Electromagnetic Q (Qes)0.68
Total Q (Qts)0.56
Compliance Equivalent Volume (Vas)0.001ft³
Mechanical Compliance of Suspension (Cms)1.057mm/N
BL Product (BL)2.3T·m
Maximum Linear Excursion (Xmax)0.95mm
Surface Area of Cone (Sd)5cm²
Cone MaterialAluminum / Magnesium
Surround MaterialFoam
Voice Coil Wire MaterialCCA
Magnet MaterialNeodymium
Overall Outside Diameter1.41"
Baffle Cutout Diameter1.14"
Depth0.52"
Sealed Volume0.001ft³
Sealed F3311.8Hz
Vented Volume0.003ft³
Vented F3177.6Hz
MONSTER DEAL
OF THE WEEK
$45.98 EACH
SAVE $12
Dayton Audio KABD-250 2 x 50W All-in-one Amplifier Board with DSP and Bluetooth 5.0 aptX HD
