  • HDMI 4x1 Quad Multi-Viewer with Seamless Switch
Part #180-1101
Part #180-1101
Combine four HDMI sources into one HDTV or HDMI PC monitor and view them simultaneously with this quad multi-viewer. Keep track of up to four sports or cameras without changing channels or inputs.
  • Compliant with HDMI 1.3a and HDCP 1.2
  • Built-in video scaler to increase or decrease resolution as needed
  • Includes IR remote to control sound and split screen size
  • Output resolution 720p, 1080p for HD quality picture
  • Includes two brackets for secure mounting
Your Price: $79.98
MSRP: $120.99
Save $41.01 (34%)
Quantity:Qty: 1-3 $79.98/ea
Quantity:Qty: 4+$74.98/ea
45In Stock
View Four HDMI Sources On One  Display at the Same Time
Combine four HDMI sources into one HDTV or HDMI PC monitor and view them simultaneously with this quad multi-viewer. This lets you keep track of up to four sports or cameras without changing channels or inputs. The quad multi-viewer displays four HDMI input sources on one screen with five multi-view modes. It also switches seamlessly between the four HDMI inputs.
Control the quad multi-viewer in three different ways. IR remote is the most convenient way to switch between the five modes, audio source, and power. Two push buttons are on the front panel to switch between the modes and audio source is the second option. The last option requires you to hard wire to an RS232 port using pin 2, 3, and 5.
Specifications: • Video amplifier bandwidth: 2.25 Gbps • Power Requirements: 12 VDC @ 2A • Input resolution: Up to 1080p 60 Hz • Output resolution: 720p, 1080p • Chassis material: Metal • Dimensions: 5.83" W x 4.06" D x 0.85" H (148 x 103 x 21.5 mm).
Part Number180-1101
UPC848864056548
Weight1.3
Audio Input/OutputHDMI
Video Input/OutputHDMI
