  • Grip Tools 54020 Small Waterproof Utility/Equipment Case with Removable Foam
CLEARANCE Grip Tools 54020 Small Waterproof Utility/Equipment Case with Removable Foam
Grip On Tools
Part #365-241
Grip On Tools
Part #365-241
Model: 54020
Protect your small electronic components, tools and other valuables with this IP65 rated waterproof carrying case. It works perfect for wired and wireless microphones.
  • Strong reinforced polypropylene watertight and dustproof protective case
  • Pick and pull foam insert for form fitting impact-absorbing protection
  • Adjustable pressure relief valve equalizes pressure
  • Convenient fold down carrying handle
Carry your most important electronic components in this Grip Tools 9.5" x 7" x 4" watertight case. It holds items up to 6.75" x 4.25" x 2.25" leaving 3/4" of foam to absorb shock. Pick out the small pieces of foam until your item fits snuggly into the case. Total inside dimensions without foam is 8.125" x 5.625" x 3.75". The IP65 rated waterproof case will keep rain and dust out to protect you equipment. Relieve pressure when changing altitude by unscrewing the knob in the front of the case. The valve must be screwed in completely before exposing the case to water or elements.
BrandGrip On Tools
Model54020
Part Number365-241
UPC097257540205
Weight1.85
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
