  • Goldwood GW-412D 12" Poly DVC Subwoofer
Goldwood
Part #290-367
Goldwood
Part #290-367
Model: GW-412D
This woofer provides added versatility over single voice coil woofers by allowing the use of both channels of a stereo amplifier to driver one speaker, and the ability to wire the voice coils in varying configurations.
Your Price: $39.98
MSRP: $64.99
Save $25.01 (38%)
Order in the next 3 hr 47 min to ship today. Details
Only 3 In Stock
This woofer provides added versatility over single voice coil woofers by allowing the use of both channels of a stereo amplifier to driver one speaker, and the ability to wire the voice coils in varying configurations. They feature polymer laminated paper cones, treated foam surrounds, and vented pole pieces with back plates. This driver features a fully shielded motor. Note: All parameters are with voice coils connected in parallel.
BrandGoldwood
ModelGW-412D
Part Number290-367
UPC643420100624
Weight5.8
Nominal Diameter12"
Power Handling (RMS)130 Watts
Power Handling (MAX)260 Watts
Impedance16Ω
Frequency Response33 to 2,000Hz
Sensitivity94dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)37.8Hz
DC Resistance (Re)3.4Ω
Voice Coil Inductance (Le)0.05mH
Mechanical Q (Qms)5.76
Electromagnetic Q (Qes)0.83
Total Q (Qts)0.73
Compliance Equivalent Volume (Vas)3.83ft³
Mechanical Compliance of Suspension (Cms)0.28mm/N
BL Product (BL)7.88T·m
Diaphragm Mass Inc. Airload (Mms)63.5g
Maximum Linear Excursion (Xmax)3.5mm
Surface Area of Cone (Sd)525.9cm²
Cone MaterialCoated Paper
Surround MaterialFoam
Overall Outside Diameter12"
Baffle Cutout Diameter11"
Depth5.1875"
Sealed Volume3ft³
Sealed F346.4Hz
Vented Volume3.5ft³
Vented F336.3Hz
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
