  • Goldwood GW-406D 6-1/2" Poly DVC Subwoofer Shielded
Goldwood
Part #290-352
Goldwood
Part #290-352
Model: GW-406D
These woofers provide added versatility over single voice coil woofers by allowing the use of both channels of a stereo amplifier to driver one speaker, and the ability to wire the voice coils in varying configurations.
Your Price: $15.18
MSRP: $24.99
Save $9.81 (39%)
Order in the next 0 hr 42 min to ship today. Details
This woofer provides added versatility over single voice coil woofers by allowing the use of both channels of a stereo amplifier to driver one speaker, and the ability to wire the voice coils in varying configurations. They feature polymer laminated paper cones, treated foam surrounds, and vented pole pieces with back plates. This driver features a fully shielded motor.
Note: This woofer has dual 8 ohm voice coils. All parameters below are with the voice coils connected in parallel for a 4 ohm load.
BrandGoldwood
ModelGW-406D
Part Number290-352
UPC643420100594
Weight3.2
Nominal Diameter6-1/2"
Power Handling (RMS)60 Watts
Power Handling (MAX)90 Watts
Frequency Response59 to 6,000Hz
Sensitivity85dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)60.3Hz
DC Resistance (Re)3.5Ω
Voice Coil Inductance (Le)0.4mH
Mechanical Q (Qms)4.13
Electromagnetic Q (Qes)0.75
Total Q (Qts)0.63
Compliance Equivalent Volume (Vas)0.47ft³
Mechanical Compliance of Suspension (Cms)0.51mm/N
BL Product (BL)4.95T·m
Diaphragm Mass Inc. Airload (Mms)13.7g
Surface Area of Cone (Sd)136.35cm²
Cone MaterialPoly
Surround MaterialFoam
Overall Outside Diameter6.5"
Baffle Cutout Diameter5.625"
Depth3.3125"
Sealed Volume0.47ft³
Sealed F377.8Hz
Vented Volume0.9ft³
Vented F348.7Hz
