  • Goldwood GM-450PB 2" High Frequency Horn 4 Bolt
Goldwood
Part #270-204
Goldwood
Part #270-204
Model: GM-450PB
These large format horns are extremely durable and will withstand the rigors of any PA application.
  • Horn dimensions: 17.7" W x 9.8" H x 9.1" D
  • Large format horn for 2" drivers
  • 90° H x 40° V dispersion
  • Heavy-duty reinforced ABS construction
  • Useable to 500 Hz
Your Price: $41.58
MSRP: $76.99
Save $35.41 (46%)
These large format horns are extremely durable and will withstand the rigors of any PA application. Excellent pattern control and directivity down to the lower frequency limit of 500 Hz. The 3/8" thick ABS construction with reinforcing ribs supports the heaviest of 2" exit compression drivers with ease.
Specifications: • Throat diameter: 2" • Bolt pattern: four holes on 4" diameter circle • Cutoff frequency: 500 Hz • Nominal coverage: 90° H x 40° V • Horn dimensions: 17.7" W x 9.8" H x 9.1" D • Cutout dimensions: 15-3/4" W x 8" H.
BrandGoldwood
ModelGM-450PB
Part Number270-204
UPC643420710045
Weight5
ConstructionABS
Entry / Throat Diameter2"
Mounting Type4-Bolt
