Gemini AS-2110BT 10" Bluetooth Active LoudspeakerThe Gemini AS-2110BT Active Loudspeaker is a powerhouse of performance wrapped in a compact, transportable design. Featuring a 10" woofer and Bluetooth connectivity, this speaker delivers expansive sound across a wide frequency range. The built-in Class AB amplifier ensures a robust sound output, perfect for any setting, while its lightweight construction and ergonomic handles make it easy to carry from one gig to another. Whether streaming music wirelessly, connecting various audio sources, or linking additional speakers, the AS-2110BT offers seamless integration and unmatched audio fidelity.
At its core, the AS-2110BT features a premium 10" woofer paired with a 2" high-efficiency voice coil, engineered to produce detailed highs, crisp mids, and resonant lows. This combination ensures your music or voice is delivered with clarity and depth, regardless of the setting.
Bluetooth technology allows you to wirelessly stream music from your smartphone, tablet, or computer, offering unparalleled convenience for setting the mood at any event without the hassle of cables.
With multiple input options including XLR, 1/4", and RCA, the AS-2110BT seamlessly integrates into any audio setup. The XLR Mix Output further enhances its versatility, allowing you to link multiple speakers for a cohesive sound system.
Built with the mobile entertainer in mind, the AS-2110BT boasts a durable ABS enclosure and ergonomic handles for easy transportation. Whether you're a touring musician or a roving DJ, this speaker is built to accompany you on all your adventures.
Fine-tune your audio with the onboard 2-band EQ and independent volume controls. Whether adjusting for room acoustics or personal taste, the AS-2110BT gives you the control needed to achieve the perfect sound signature.
- Amplifier Power: 1000W peak
- 10" Low Frequency Driver
- Piezo High Frequency Driver
- Two Microphone Inputs (1/4" or XLR)
- Three Line Inputs (XLR, RCA or 1/8")
- Frequency Response: 55 Hz- 20,000 Hz
- Clip LED
- Bluetooth with True Wireless Stereo (TWS) Linking
- Wireless Remote Included
