Gemini AS-2108BT 8" Bluetooth Active LoudspeakerThe Gemini AS-2108BT Active Loudspeaker offers a comprehensive solution for all your audio needs. With its 8" woofer and integrated Bluetooth connectivity, this speaker delivers dynamic sound across all frequencies, ensuring your music or voice cuts through any mix. The built-in amplifier provides consistent, high-powered output, while the lightweight design makes it easily transportable for gigs, presentations, and outdoor events. With the AS-2108BT, you can stream music wirelessly, connect microphones, or link up with other audio equipment for a seamless audio experience.
At the heart of the AS-2108BT lies an 8" woofer with a 2" voice coil, engineered to produce the crisp highs and deep lows that define quality sound. Whether for music, speeches, or live performances, this speaker ensures your audio is always impactful and immersive.
Bluetooth connectivity transforms the AS-2108BT into a versatile streaming powerhouse. Effortlessly connect your mobile devices to play tracks or background music wirelessly, perfect for creating the right ambiance at any event.
Versatility is key with the AS-2108BT, offering a range of input and output options. Whether you're connecting microphones, musical instruments, or other speakers, this loudspeaker accommodates all your audio sources seamlessly.
Designed with portability in mind, the AS-2108BT features a lightweight, rugged ABS enclosure and a convenient top handle. This makes transportation and setup a breeze, whether you're moving from gig to gig or setting up for an outdoor event.
Fine-tune your sound with the onboard 2-band EQ and independent volume control. Whether you need to boost the bass or adjust the treble, the AS-2108BT provides the controls you need to tailor your audio output perfectly.
- Amplifier Power: 500W peak
- 8" Low Frequency Driver
- Piezo High Frequency Driver
- Two Microphone Inputs (1/4" or XLR)
- Three Line Inputs (XLR, RCA or 1/8")
- Frequency Response: 60 Hz- 20,000 Hz
- Clip LED
- Bluetooth with True Wireless Stereo (TWS) Linking
- Wireless Remote Included
