  • GRS RT2.0-8 Hi-Res Neo Ribbon Tweeter 8 Ohm
GRS
Part #272-204
GRS
Part #272-204
Model: RT2.0-8
GRS's premium "Hi-Res" ribbon tweeters with the latest in materials and motor technology easily reach frequencies of 40kHz and beyond, adding incredible detail from your hi-fi system!
  • 2.3kHz to 40kHz frequency response for true "Hi-Res" detail
  • Powerful neodymium magnets deliver high efficiency and incredible dynamics
  • Remarkably thin ribbon diaphragm provides accurate transient detail
  • High sensitivity for increased SPL Output
  • Built-in grill protects the delicate ribbon from fingers and other foreign objects
  • Optional silver faceplate available
Your Price: $49.98
MSRP: $129.99
Save $80.01 (62%)
Order in the next 10 hr 12 min to ship today. Details
Hi-Res. High-Value.
GRS has released a line of premium "Hi-Res" ribbon tweeters employing the latest in materials and motor technology> The GRS Hi-Res Ribbon Tweeters effortlessly reach frequencies of 40kHz and beyond, adding incredible detail from your hi-fi system. This is achieved by employing incredibly light and thin diaphragms, high grade neodymium motor and attention to detail in the assembly process.
The GRS Hi-Res Ribbon Tweeters are perfect for those looking for the "Hi-Res" detail in their loudspeaker system!
Key Specs:
  • Power Handling (RMS): 20 Watts
  • Power Handling (MAX): 40 Watts
  • Impedance: 8 Ω
  • Frequency Response: 2300Hz - 40kHz
  • Sensitivity: 94 dB 2.83V/1m
  • Diaphragm Material: Aluminium Foil
  • Magnet Material: Neodymium
Frequency Response & Impedance
The GRS Neo Ribbon Tweeters have an extended frequency response that reaches up to 40kHz, this allows the tweeter to provide better transient detail and less roll-off at 20kHz than you’d normally get with typical tweeters. The relatively flat impedance curve also makes crossover design incredibly simple, with no awkward loads to work around!
  • Black: 0°
  • Red: 15°
  • Green: 30°
  • Blue: 45°
Above and beyond
As audio technology improves beyond the imagination of the last generation, GRS is here to keep you up to spec! With a diaphragm thickness of 0.03mm made from pure aluminum foil, the GRS Hi-Res Neo Ribbon Tweeters take advantage of the latest in materials and motor technology to bring you a tweeter that plays faithfully up to 40kHz!
Shop the whole GRS Ribbon Series
Optional Faceplate
Shop Now
GRS RT1.R-8
Shop Now
GRS RT2.0-8
Shop Now
GRS RT3.0-8
Shop Now
BrandGRS
ModelRT2.0-8
Part Number272-204
UPC848864069449
Weight1.9
Tweeter TypeRibbon
Power Handling (RMS)20 Watts
Frequency Response2300 - 40,000Hz
Sensitivity94dB 2.83V/1m
DC Resistance (Re)0.2Ω
Depth2.67"
