  • GRS A25-10 Replacement 10" Woofer for Dynaco A25 6 Ohm
GRS
Part #292-468
GRS
Part #292-468
Model: A25-10
The Dynaco A-25 was once celebrated for its natural and distortion-free sound reproduction; however, the passage of time has taken its toll on the original components, leaving a shadow of their former glory. GRS has created a replacement woofer that captures the essence of the original design, with the reliability you'd expect of a modern woofer! This 10-inch drop-in replacement was created for those who want to rediscover their favorite music as they once heard it.
  • Meticulously crafted replacement woofer for the Dynaco A-25 speaker
  • Lighter cone design for improved transient response and accurate music reproduction
  • Aging considerations addressed with a softer suspension and cloth dust cap
  • Fully compatible with the Dynaco A25's aperiodic bass reflex port
  • Underdamped woofer design for precise performance with the original A25 cabinet
Your Price: $89.98
MSRP: $129.99
Save $40.01 (31%)
Quantity:Qty: 1-3 $89.98/ea
Quantity:Qty: 4+$80.98/ea
Order in the next 3 hr 12 min to ship today. Details
Retro Sound, Modern Performance - Reignite your Dynaco A-25 Experience
Rediscover the legacy of the Dynaco A-25 speaker with our meticulously crafted replacement woofer. The Dynaco A-25, known for its natural, distortion-free sound reproduction, owed much of its performance to its unique woofer design. We've strived to bring that sound back to the present with our replacement woofer, ensuring that you get to relive the magic of the Dynaco A-25 once more.
Aging Considerations and Modern Improvements
We've made sure to consider the aging issues of the original, integrating a softer suspension to provide more travel room and a cloth dust cap for an authentic touch. Our replacement woofer is not just a part; it's a tribute to the revered Dynaco A-25's legacy, designed to bring its historic sound into the present.
  • Nominal Diameter: 10"
  • Power Handling: 70W
  • Impedance:
  • Frequency Response: 50Hz - 4500Hz
  • Sensitivity: 90.4dB 2.83V/1m
  • Voice Coil Diameter: 1.5"
  • Maximum Linear Excursion: 4.5mm
Lighter Cone, Higher Performance
Our woofer boasts a light cone, that promises an improved transient response. This means that rapid changes in the music are accurately reproduced, giving you an unmatched audio experience, just as the original.
A Well-Designed Drop-in
We've taken care to ensure the woofer is fully compatible with the A25's aperiodic bass reflex port. This principal allowed the speaker to deliver deep bass from a relatively small enclosure beyond what was possible at the time. To do this we've reduced Re and Fs to underdamp the woofer ensuring exact performance when interacting with the air volume into the original A25 cabinet.
BrandGRS
ModelA25-10
Part Number292-468
UPC848864072517
Weight5.8
Nominal Diameter10"
Bolt Circle Diameter9.6
Power Handling (RMS)70 Watts
Power Handling (MAX)140 Watts
Frequency Response30 - 4500Hz
Sensitivity89.6dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)30Hz
DC Resistance (Re)6.6Ω
Voice Coil Inductance (Le)1.7mH
Mechanical Q (Qms)2.5
Electromagnetic Q (Qes)0.43
Total Q (Qts)0.37
Compliance Equivalent Volume (Vas)3.2ft³
Mechanical Compliance of Suspension (Cms)0.55mm/N
BL Product (BL)12T·m
Diaphragm Mass Inc. Airload (Mms)49.6g
Maximum Linear Excursion (Xmax)4.5mm
Surface Area of Cone (Sd)346cm²
Cone MaterialPaper
Overall Outside Diameter10"
Baffle Cutout Diameter9.05"
Depth4.54"
MONSTER DEAL
OF THE WEEK
$129.49 EACH
SAVE $14
Dayton Audio HTA20 20 Watt Integrated Stereo Hybrid Tube Amplifier With USB-DAC and Bluetooth 5.0
