  • Fourjay 312/70-T 70V Reflex Horn Paging Speaker
2 Questions, 2 Answers or
Fourjay Industries
Part #300-074
Model: 312/70-T
Rated at 12 watts continuous duty, the 312 series reflex horn speaker offers good frequency range for music and paging applications in moderately noisy environments and a strong but lightweight construction of impact resistant ABS.
Your Price: $102.98
MSRP: $146.99
Save $44.01 (30%)
Quantity:Qty: 1-5 $102.98/ea
Quantity:Qty: 6+$98.86/ea
Rated at 12 watts continuous duty, the 312 series reflex horn speaker offers good frequency range for music and paging applications in moderately noisy environments. With a strong but lightweight construction of impact resistant ABS, it is strong enough to be mounted with a stud gun or concrete nails. The unique polycarbonate mounting base assembly and stainless steel fasteners offer two hole patterns for quick and easy mounting and adjustments allowing assembly to various electrical boxes. May also be recess mounted using the hole locations dimpled on the back of the flange. Tan in color. Available in 8 ohm and 70.7V versions. Made in the U.S.A.
Specifications: • Rated input: 70.7V line • Power taps: 12, 6, 3 & 1 watts • Frequency range: 400-5,000 Hz • Sensitivity: 97 dB • Mfg. #312/70-T • Net weight: 2-1/2 lbs.
BrandFourjay Industries
Model312/70-T
Part Number300-074
UPC844632007361
Weight4.2
Speaker TypePA Horn Speaker
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
