  • Fountek NeoCD1.0 Ribbon Tweeter
CLEARANCE Fountek NeoCD1.0 Ribbon Tweeter
Fountek
Part #296-701
Fountek
Part #296-701
Fountek’s NeoCD1.0 is a value leader in affordable ribbon tweeters, delivering the incredible detail that ribbon tweeters are known for at a price that is easily within reach. Its round faceplate is easily recessed using conventional tools.
  • 1.5" H x 0.315" W ribbon element
  • Wide 2,000-40,000 Hz frequency response
  • Excellent horizontal off-axis dispersion for a wide listening window
  • Circular faceplate for easy mounting
The NeoCD1.0 ribbon tweeter is Fountek's most accessible ribbon tweeter with an affordable price, and a round faceplate that is easy to recess into loudspeaker baffles using the same tools used for recessing other round drivers.
A reinforced, sandwiched-aluminum ribbon and high-strength neodymium motor structure portray musical detail with incredible accuracy and speed, with an incredible frequency response that extends out to 40,000 Hz, while the wide horizontal off-axis dispersion makes for a larger listening sweet spot. Recommended minimum crossover frequency: 3,500 Hz @ 18 dB/octave
BrandFountek
ModelNeoCD1.0
Part Number296-701
UPC848864004099
Weight1.05
Cutout Diameter2.60" x 2.17
Tweeter TypeRibbon
Power Handling (RMS)12 Watts
Frequency Response2,000 to 40,000Hz
Sensitivity90dB 2.83V/1m
Overall Outside Diameter3.94"
Depth2.6"
