Fosi Audio BT30D Pro 2.1 Channel Bluetooth Hi-Fi Amplifier 165W x 2 + 350W x 1
- Bluetooth 5.0 delivers a connection range of up to 50 feet
- A separate, 350 watts at 4 ohms subwoofer output will make you feel the bass, not just hear it
- Treble, bass, sub volume, subwoofer frequency controls will let you dial in your system to just where you like it
- A TI TPA3255 class-D power amplifier chip delivers high power but a power-efficient performance
- Two 60 mΩ MOSFETs optimize performance to deliver significantly lower idle losses than common to comparable amps
- A 3.5mm pre-out gives you the option of connecting to a whole second audio system
- 32V 5A power supply included
We'll send you an email when Fosi Audio BT30D Pro 2.1 Channel Bluetooth Hi-Fi Amplifier 165W x 2 + 350W x 1 is back in stock or available for preorder.
